NAVISURFER II™ is the first indash 1-DIN computer with a combination of 7" touch screen monitor. Monitor able to move as vertically as well horizontally. NAVISURFER II™ allows to run any normal Windows or Linux compatible applications also serves as Audio / Video Player, Vehicle GPS Navigator & Tracker, Rear View Camera, In-Car wireless Internet, In-Car TV, In-Car Game Console and In-Car Mobile Office and real-time OBD-II vehicle diagnostics.
NAVISURFER II™ is compatible with any passenger or commercial vehicle wich has a 1DIN / Single DIN. It's easy to install and doesn't require any professional skills. Simply install into single DIN slot connect power cable to the car battery and sound cable to the car speakers and you are ready to go.
Models
NavisurferII 40GB
Processor: 1.3 Mhz
Hard drive: 40GB
RAM: 256MB
NavisurferII 80GB
Processor: 1.3 Mhz
Hard drive: 80GB
RAM: 256MB
NavisurferII 120GB
Processor: 1,0 Mhz
Hard drive: 120 GB
RAM: 512MB
Weight & Dimensions
2,5 kg
Operating Temperature & Humidity
-10 to 65 Degrees Celsius (14F-140F)
0% ~ 93% (relative humidity; non-condensing)
Power Supply
Intelligent Vehicle Power Supply
ATX, 12V input
Intelligent shutdown controller, powers on and off with ignition.
ON/OFF motherboard control
Survives vehicle engine cranks
Battery deep discharge prevention
High efficiency, 120 watts output
Works with 12V car batteries
Hard Drive
2.5" Drive
Anti-shock mounting
High non-operating shock tolerance by load / unload technology Monitor
Computer built-in
Wide vertical and horizontal movement angle
Display size: 7 inches (16:9)
Physical resolution: 800 x 480 RGB, highest resolution: 1024 x 768 formatted
Visual angle: 150, contrast: 350 ?brightness: 500
Dot distance: 0.06*0.18mm
Response time: Tr+Tf =16ms
Touch screen
Accessories
User Manual, Driver CD, Bluetooth Dongle
"navisurferII"
ARRANCA LA COMU?
1) ROLO
