Códigos de Fallas Vitara 91'-95' EFI 16V Motor G16B
Vitaris93
Nota por Vitaris93 »
Este es un Tip para diagnosticar una falla en el motor G16B, fue sacado de otro foro, está en inglés, no quiero traducirlo textualmente porque prefiero que cada uno lo interprete. Puede servir para dar en el clavo de la falla y no andar como loc sin manija de mecanico en mecanico, pero... hay que animarse a hacerlo.:
The following procedure is for early model (1991 to about 1995) EFI 16v Vitaras (G16B)
Beside the relays just in front of the battery in the engine bay is a "Monitor Coupler"
It is a small 4 pin female plug with a rubber cover.
Remove the rubber cover and holding the plug so that the narrower, rounded end is at the top, put a wire from the top right pin (diagnosis switch terminal) to the bottom left pin (ground). See picture.
Switch the ignition to 'ON' but dont start the engine. Watch the "CHECK ENGINE" light and it will flash. It will flash a number of times, one second break, flash again. Count the flashes before and after the pause and you will get a 2 digit number. eg 1 flash, 1 second break, 2 flashes -> 12 -> Normal operation.
DIAGNOSTIC TROUBLE CODES
13 heated oxygen sensor
14 engine coolant temp sensor
15 engine coolant temp sensor
21 throttle position sensor
22 throttle position sensor
23 intake air temperature sensor
24 vehicle speed sensor
25 intake air temperature sensor
33 mass air flow sensor
34 mass air flow sensor
41 ignition fail safe signal
42 camshaft position sensor
44 idle switch of throttle position sensor
45 idle switch of throttle position sensor
51 EGR system
52 Fuel system
53 ECM spec
ON ECM failure
12 Normal state.
RESET
Remove power to ECM for 20 seconds (Remove battery negative terminal)
Imágen del conector:
(click aquí para ver la imagen ampliada)
http://www.outerlimits4x4.com/PHP_Modul ... p?id=13441
Espero que sirva el dato.
Posteado en www.outerlimits4x4.com
Manu
Algo interesante....
Nota por Manu »
Ahora que lo mencionás, tengo en mi haber un CD con data técnica de varios modelos de Suzuki, despieces de motor, esquemas eléctricos, códigos de error, valores de reglaje, localización de averías, programas de revisión cada 15M Km, etc. ( hay también de autos de la marca, pero en TT tengo: Jimny, Samurai, LJ80, Vitara y la figurita dificil :shock: : la Grand Vitara en todas sus versiones!!!)
Así que si alguien necesita la data, que me la solicite y con todo gusto será proporcionada!! :wink:
SLDS!! :B:
Salu2 :B: - Juan Manuel (#49)
GV 2001
SW4 2008
Si no encontrás el camino, poné la doble y HACELO VOS!!!.... :freude:
Vitaris93
MANUCHEN!!!!!
Pasále la info al Web Master para que la suba!!!!
Vamos carajo que recopilamos una PILA de info de las zukis!
Gabryel
Nota por Gabryel »
En el sector de manuales, esta el del vitara, en castellano. Esta muy bien indicado como hacer el autodiagnóstico mediante el “borne de diagnostico” del check engine.
También hay una lista donde indica que código corresponde a los parpadeos del testigo check engine, esto es lo que acusa la falla.
Esto ultimo es lo que le faltaría al tip en ingles.
Es un labarito muy sencillo.
Gabriel
anghelo
Re: Algo interesante....
Nota por anghelo »
saludos gabryel :quisiera pedirte un favor tambien quisiera el manual de suzuki vitara, yo tengo un problema, mi suzuki es un escudo 2.0 con motor h20a y no encuentro un manual de usuario para ese coche y te pregunto si en el cd que tu tienes habla del escudo y motor h20a
si asi es te ruego que me facilites informacion de antemano gracias
Manu escribió:Ahora que lo mencionás, tengo en mi haber un CD con data técnica de varios modelos de Suzuki, despieces de motor, esquemas eléctricos, códigos de error, valores de reglaje, localización de averías, programas de revisión cada 15M Km, etc. ( hay también de autos de la marca, pero en TT tengo: Jimny, Samurai, LJ80, Vitara y la figurita dificil :shock: : la Grand Vitara en todas sus versiones!!!)
SLDS!! :B:
anghelo
Nota por anghelo »
saludos manu te escribo para pedirte por favor que me desde una mano con el cd para el suzuki escudo h20a, lo necesito con urgencia, mi problema es que de un tiempo a esta parte a comensado a cabecear el motor en ralenti en D es peor y no encuentro la causa probable de antemano te agradesco gracias.
SLDS!! :B:
