Description of Electric Throttle Body System
S5JB0A1101009
The Electric Throttle Body System consists of electric throttle body assembly, accelerator pedal position (APP) sensor
assembly, ECM and throttle actuator control relay.
Among them, assembly components are as follows.
• Electric throttle body assembly: throttle valve, throttle actuator, 2 throttle position sensors
• Accelerator pedal position (APP) sensor assembly: Accelerator pedal, 2 accelerator position sensors
Operation Description
ECM (5) detects opening (depressed extent of pedal) ofthe accelerator pedal based on signal voltage of the
accelerator pedal position (APP) sensor (1) and using that data and engine operation condition, it calculates the
optimum throttle valve opening. On the other hand, it detects the throttle valve opening based on the signal voltage of
the throttle position sensor (3) included in the throttle body (2) and compares it with the above calculated optimum
throttle valve opening. When there is a difference between them, ECM controls the duty ratio (100% – 0%) of throttle
actuator control according to this difference to drive the throttle actuator (motor) (4) included in the throttle body. When
there is no difference, ECM controls the duty ratio of throttle actuator control to about 15% to maintain the throttle
valve opening. In this way, the throttle valve (17) is opened and closed to achieve the optimum throttle valve opening.
In this system, as the throttle position sensor and accelerator pedal position (APP) sensor have 2 sensors (main and
sub) each, highly accurate and highly reliable control and abnormality detection are assured. Also, when ECM detects
an abnormality in the system, it turns off the throttle actuator control relay (8) tostop controlling the throttle actuator.
When the throttle actuator control relay is turned off, the throttle valve is fixed at the opening of about 7°from its
completely closed position (default opening) by the force of the return spring and open spring included in the throttle
body.
This throttle body is not equipped with IAC valve for idlespeed control. Idle speed control is done by the throttle
actuator which opens/closes the throttle valve.
4
1
2
17
3
5
6
7
8
9
10
11
12
13
14
15
16
18
I4RS0B110007-02
6. CPU 11. Accelerator pedal position (APP) sensor
(main) signal
15. Drive signal of throttle actuator
7. Drive circuit of throttle actuator 12. Accelerator pedal position (APP) sensor (sub)
signal
16. Power supply of throttle actuator
9. From “THR MOT” fuse 13. Throttle position sensor (main) signal 18. Control signal of throttle actuator control relay
10. From main relay 14. Throttle position sensor (sub) signal
PUCHA NO SALEN LOS DIBUJOS
solo probando a ver si resulta hmmmm no salen los dibujos
- literaider
