Estado: Nueva. Sin uso.
Características brindadas por el fabricante:
LED Power: 72W
Operating Voltage: 10-30V DC
Waterproof rate: IP 68
24PCS*3W high intensity LEDs
Current draw 6A @ 12V, 3A @ 24V
Base Color: Black
Color Temperature: 6000K
Material: Diecast aluminum housing
Lens material: Toughed glass
Mounting Bracket: Alu firm bracket
30000 hours above life time
Dimensions: 12 inch in width
Beam Type: Flood and Spot
Casting Aluminum Alloy Housing
The Quart Lens with high light transmission
Applying to difference light resource(Such HIGH LED Lamp)
The suitable design for heating elimination.
Dust-proof,Quake-proof.
Anti explosion
Unit Dimensions: 302mm (width) x 106mm (length including mounting) x 64mm (depth)
Unit Dimensions in inches: 11.88 inch (wide) x 4.3 inch (tall including mounting) x 2.56 inch (deep)
Weight: 2kg (Included Box).
Precio: $3400
Precio Suzuki Club: $3100
Se pueden retirar por Florida (Zona Norte prov Bs As) o envío a cualquier parte del país en micro o como indiquen
Envio a cargo del comprador.
