Amigos son los codigos del suzuki sidekick sport 1997 NO del 1998
DTC Table
DTC No. Trouble Area Detecting Condition
(DTC will set when detecting) “O/D OFF” Light MIL
P0705 Transmission range switch circuit malfunction Multiple signals are inputted simultaneously or no signal of “R”, “N”, “D”, “2” or “L” range is inputted while running at 60 km/h or more. 2 driving cycles
P0720 Output speed sensor circuit malfunction No output speed sensor signal is inputted during VSS signal input. 2 driving cycles
P0741 TCC (lock-up) solenoid performance or stuck off ON / OFF control from PCM to TCC does not agree with actual TCC operation. 2 driving cycles
P0743 TCC (lock-up) solenoid electrical Monitor signal ON is detected at TCC solenoid OFF. 1 driving cycle
Monitor signal OFF is detected at TCC solenoid ON.
P0751 Shift solenoid A (#1) performance or stuck off Gear change control from PCM to A/T does not agree with actual gear position. 2 driving cycles
P0753 Shift solenoid A (#1) electrical Monitor signal ON is detected at shift solenoid A (#1) OFF. 1 driving cycle
Monitor signal OFF is detected at shift solenoid A (#1) ON.
P0756 Shift solenoid B (#2) performance or stuck off Gear change control from PCM to A/T does not agree with actual gear position. 2 driving cycles
P0758 Shift solenoid B (#2) electrical Monitor signal ON is detected at shift solenoid B (#2) OFF. 1 driving cycle
Monitor signal OFF is detected at shift solenoid B (#2) ON.
P1875 4WD low switch circuit malfunction Output speed / back-up speed ratio of 4WD low range is detected when 4WD low switch is OFF or output speed / back-up speed ratio of other range detected when it is ON. 2 driving cycles
Mas codigos del suzuki sidekick sport 1997
Atentamente, Antares 2009
