entendidos en VHF consulta
JuanG MDQ
Nota por JuanG MDQ »
les pido a los entendidos en vhf/handy si me pueden informar que tal es este equipo. yo actualmente tengo un yaesu ft-23R pero esta bastante curtido y sugio la posibilidad de importar estos equpos a muy buen precio.
desde ya muchas gracias !!
100% Brand New
Feidaxin FDC FD-160A (VHF 136~174 ) Two Way Radio in MINT condition.
(+ PTT (E-066M) Earpiece for free!)
All Feidaxin radio comes with 1-year warranty !
Up for Sale is a 100% Brand New Feidaxin FDC FD-160A (VHF 136 - 174Mhz) Two Way Radio in MINT condition. + (PTT (E-066M) earpiece/mic(FREE))
Features:
Built-in 50groups of CTCSS and 104 groups of DCS
- LCD&keypad backlit display ,blue digital keyboard
- Standby time:120hours
- Scan function,keypad lock
- Rainproof
- Hi/Lo power select(1W-5W)
- Programming method:computer/manual
- Charger LED indicator(red-charging;green-fully chaged)
- Signal strength indicator
- Key sound
- Battery indicator
- Semi-duplex operation
- Reverse Frequency
- Adjustable squelch
Specifications:
Model No.
FD-160A
General
Frequency Band
VHF
Frequency Range
136 - 174 MHz
Channel Capacity
99
Operating Voltage
6V DC ± 15%
Antenna Impedance
50ohms
Channel Spacing
25KHz
Working Temperature
-30°C ~ +60°C
Frequency Stability
± 2.5ppm
Size (without antenna)
56(W) x 106(L) x 32mm(D)
Weight (with battery)
About 250g
Battery
1,300mAh(Ni-Mh)
Compatible with American Military Standard
(MIL-STD-810C/D/E)
Transmitter (EIA-RS 316B Standard)
RF Power Output
4W/5W
Modulation Type
F3E
Modulation Distortion
<5% (300 - 3,000Hz)
Maximum Frequency Deviation
<5KHz (1,000KHz when 100%)
FM Noise
<= -45dB
Receiver
Sensitivity (12Db SINAD)
0.16μV
Selectivity
55dB
Adjacent Channel Selectivity
>= 70dB
Noise Respond
>= 60dB
Communication Range
3 - 5km (downtown), 6 - 20km (in the open area)
FM Noise
45dB / 40dB
Modulation Type
16KOF3E
Audio Power Output
500mW when distortion less than 10%
Audio Distortion
<5%
Operating Bandwidth
± 7KHz
Standby Current
<10mA
socio *5382*
Si el precio es bueno, el equipo parece lindo
Hay que probar la calidad de sonido y potencia, ver si calienta, si calienta ver si distorsiona, etc
No creo que sea malo, hay muy buena electrónica hoy por hoy, con lo cual es raro que esto falle
Yo no lo use nunca, pero no lo descartaría por eso. Habría que probarlo
Suerte
JuanG MDQ
gracias dany !
calculo que quedarian a mas menos $300, nuevos.
socio *5382*
Me parece un muy buen precio
Yo lo probaría :wink:
Y acordate que para usar esos equipos, es necesaria la correspondiente licencia :cool:
JuanG MDQ
DanyEl14 escribió:Me parece un muy buen precio
si, si claro !, si no tendria licencia, no usaria estos equipos ! [-X
socio *5382*
:wink:
:mrgreen:
zx600
Nota por zx600 »
Atenti !!!!!!!!!!!, que la especificación dice separación de canales en saltos de 25 Khz !!!!!!!!!!!!!, mientras que aqui usamos separación en saltos de 5 Khz.
Daniel - SUZUKERO Nro.82
FERSEDICIVALVOLE
Nota por FERSEDICIVALVOLE »
Hola, yo no se si lo vas a hacer como negocio, o te vas a traer uno o dos para vos.
de ser este ultimo caso, fijate bien cuanto esta en mercado, porque al final terminas pagando solo un poco menos por algo que si despues tiene problemas, fuiste
yo me traje un icom usado, y entre una cosa y la otra, termina pagando lo mismo que vale usado aca y encima lo rompi, asi que para no hacerma mala sangre ni lo voy a abrir
aparte de todo, si los queres traer como dios manda, tenes regulaciones que tenes que cumplir para que puedan ser liberados en aduana, que no son precisamente las mas faciles y economicas.
evalua bien todo antes de embarcarte, a mi las ultimas tres importaciones informales ( llamese correo) me salieron como el tujes, porque sacaron una nueva resolucion en la que te cobran no solo el 50% del producto, sino tambien del envio, son unos chantas.
a menos que te lo traigas abajo del brazo en un viaje o tengas algun otro metodo, averigua todo bien antes
fernando
JuanG MDQ
zx600 escribió:Atenti !!!!!!!!!!!, que la especificación dice separación de canales en saltos de 25 Khz !!!!!!!!!!!!!, mientras que aqui usamos separación en saltos de 5 Khz.
:shock: :shock: lo que ?
socio *5382*
FERSEDICIVALVOLE
quiere decir que por ejemplo yo uso con otro club la frecuencia 14x.x30 y si los saltos son de 25 y no se puede modificar ,no podrias sintonizar esa frecxuencia, por ejemplo patagonia :mrgreen:
tongab
Nota por tongab »
Hola Juan, metele para adelante con el chinito que anda bien.. aca en Rosario compramos cerca de 10 de estos equipos tentados por el precio. (hasta compraron los muchachos de radioclub donde hicimos el curso de RA)
Llegaron todos sin problemas (algunos directo al domicilio y otros los tuvimos que buscar en la aduana, pagando el aracel correspondiente, que igual resulta barato)
yo tengo Base Icom y un Handy Vertex.. pero bueno, era muy barato para desaprovecharlo y nunca esta de mas
obvio que las funciones son muchas menos que las de un handy de marca reconocida, pero las funciones basicas estan.. el alcance similar. se escucha muy bien. la bateria dura mucho por ahora...
que vida util tendran no se, seguro algo menos tambien que uno de marca reconocida (y cuesta 1/3 menos) . por ahora van 8 meses desde que llego el primero y ninguno tubo problemas
Tonga
Pasion 4x4 Rosario
tongab
Nota por tongab »
te confirmo que los saltos son de 5 Khz.
por el tema de la aduana, los primero equipos llegaron directo al domicilio del comprador..(no pagaron arancel) los ultimos los tuvimos que buscar en aduana
el handy sale 25usd en Ebay + 30usd de envio internacional = 58usd
en aduana se fijaron en la pagina del fabricante y figura a 56 uds el equipo, pero vos en forma particular tenes una franquisia de 25usd anuales (un chiste)
haces 56usd (valor de mercado del equipo) - 25usd (franquisia) = 31usd, sobre esto te cobran el arancel del 50% o sea 15usd
con impuestos y todo te sale 73 USD a $ 3.5 son algo asi como $ 255! muy barato!
y andan OK
Tonga
Pasion 4x4 Rosario
FERSEDICIVALVOLE
TONGA, MIRA QUE YO LA SEMANA PASADA MANDE A BUSCAR EL BLOQUEO Y SE VE QUE COMO MUCHOS ARREGLAN ALLA PARA QUE TE COBREN POCO ACA, QUE TE PONGAN ALTOS LOS GASTOS DE ENVIO Y BAJO EL DEL PRODUCTO, DIRECTAMENTE TE ESTAN COBRANDO EL 50% DE TODO, CON SHIPPING COST INCLUIDO
SI YE LOS PROBARON, Y VAN BIEN , DALE PARA ADELANTE SON BARATOS IGUAL, SUERTE
SALUDOS
F16V
chipi
Nota por chipi »
por lo que veo es bibanda ??? o solo rx en uhf ???
Tendrías que asegurarte que esté "liberado" en tx para vhf.....
Máximo
tongab
Nota por tongab »
no es bibanda.. se pide VHF u UHF. ya viene "liberado"
Tonga
Pasion 4x4 Rosario
JuanG MDQ
tongab escribió:te confirmo que los saltos son de 5 Khz.
y andan OK
excelente tu respuesta tongab !!, muchas gracias !!, me quedo clariimo todo !!!
ya me registro y pido uno !!!
socio *5382*
JuanG MDQ
y andan OK
socio *5382*
